Rear Bearing Seals
Bowman74
Rear Bearing Seals
Post by Bowman74 »
I have been able to locate the rear bearings for my 412 without a problem. However, I have not been able to find the seals (two per side). Does anyone know the part numbers for these? Are they the same as for standard VW IRS systems?
Thanks,
Kevin
The inner and outer are both the same part#. I have a CR part # dor them, that you should be able to dross match at any bearing or seal dealer. It is.....CR-550280 Ray
Bowman74
Post by Bowman74 »
raygreenwood wrote:The inner and outer are both the same part#. I have a CR part # dor them, that you should be able to dross match at any bearing or seal dealer. It is.....CR-550280 Ray
You're the man!
Thanks,
Kevin
Bowman74
Post by Bowman74 »
Ray,
You wouldn't happen to have a bearing/seal dealer you use, do you? I've tried three different flaps and that cross reference number is NLA.
Thanks,
Kevin
There is a large bearing chain that is coast to coast....a series of dealers really, try bearings inc. Also try Purvis bearings. Just look under bearings in teh yellow pages. There should be numerous industrial bearing dealers near you. The brand...CR...is a large conglomerate of generally good stuff. That is a standard industrial bearing seal. When I get home later...i will look in my VW 411 parts list for the actual part #. Its very similar ...if not the same, to type 3. Ray
MGVWfan
Post by MGVWfan »
According to the parts book I just received today, both inner and outer rear seals are the same p/n, and that's 411 501 315B. There's also an O-ring under the outer retainer bolt, it's 411 501 237, and a seal for the bearing cover, 113 501 291. YMMV, if one can trust this parts book (International Parts Service, subsidiary of Warehousing Service Co. of LA).
Lane
67 MGB (Abingdon's Finest)
04 Golf TDI (45 MPG)
Yep, you will not find these seals at any FLAPS...but theye are common at any bearing dealer. The part # I gave you will get you a seal at a bearing dealer. The factory VW part # will not. Ray
vwbill
??? duh??
Post by vwbill »
Sorry to ask a stupid one but what seals are you talking about? Rear wheels???? Sorry bill
Have you tried the guys at street and sand toys? They sometimes can help? I Use a bearing and drive place here called bearings and drives inc 352-375-0568 those guy break out the caliper for you,lol!
Yep...VWBill has the right idea. Bearings and drives is part of that same national network of bearing jobbers....that have that symbol somehwere in their window...you know...red, blue ,black...with a pair of bearings and a couple of strips going straight up....looks oddly like a "penis".... :shock: .If your city has busniesses with machines in it...you have at least one bearing dealer. Just bring them a seal....They can match it up. This is a pretty common seal. Ray
vwbill
Any luck?
Post by vwbill »
Any luck finding your stuff? Any new sources? Bill
Bowman74
Re: Any luck?
Post by Bowman74 »
vwbill wrote:Any luck finding your stuff? Any new sources? Bill
It looks like I can get the seals here: http://www.wbds.com/ with the cross reference number that Ray provided.
Thanks,
Kevin
vwbill
New Source!
Post by vwbill »
If they come through you'll have to add it to the vendor list! Couldnt hurt to have another online source! bill
Bowman74
Re: New Source!
Post by Bowman74 »
vwbill wrote:If they come through you'll have to add it to the vendor list! Couldnt hurt to have another online source! bill
I'll let you know how it works out. They also have the Timkin 2 piece rear bearing sets (LM78349 bearing and LM78310A race).
Thanks,
Kevin
Bowman74
Re: New Source!
Post by Bowman74 »
Well I got the seals today. They certianly look correct but I won't know until I put them in the car.
Thanks,
Kevin
A note....these seals can be hard to put in, especially the inner one. Its wsorth ot to "make" a seal driver. Go down to a local nut and bolt company. What you want...are washers with an outside diameter either just a hair smaller....or larger....then you can grind them down. But...they will probably be about $2 ea. Get three. They should have anywhere from a 1/2"-3/4" hole in the center. Get a fat piece of all thread and two lock nuts and washers. Between the nut and bolt dealer and homo depot....itshould run about $12-15. Use that to tap the inner seal in flat. Ray
