parts no. question
albert
parts no. question
allo ray if we see in (example ) the PELICAN PARTS katalogue the parts no. ,,,,411-325-150 ,,, fictif no,,, the 411 no. is good for 411-412 car application , if my mémory is good the tree first no, is for the car no, (exa. 411,,, type 4 ,,,311 type 3 ,,,211 ,,,type 2 , that supposition is exact for all the parts ???
- tuna
Kind of. The first number of the VW part number system is the ORIGINAL vehicle the parts was designed/used for. For instance, the part number for pedal pads of the T1 and T3 is:
311-721-173A
This meant that the part was originally used on the Type 3 (311), but it also works with the Type 1. Oil pressure switch for a Bug (021-919-091B) was originally from a Type 4 (021 is usually a 1.7 T4 engine part #).
Make sense?
Tuna
311-721-173A
Make sense?
Tuna
http://vdubgeek.blogspot.com/
Type 4: Secrets Revealed - https://type4secrets.blogspot.com/
Tom's Type 4 Corner - coming soon!
EMPI Imp Homepage - coming soon!
My VWs - http://vdubgeek.blogspot.com/p/my-vdubs_5.html
albert
parts no.
oh, yes, tom , some time he have the parts for geral application , and different model of car can use the same number ,,vw name that (substitut )the pelican cie. is a specialist for porche 914 and if you look in the parts catalog ,,,brake pads, or calper kit , for 914 you see the parts no...411 ???,??? the first application was for 411 but can fit on 914 and oders vw car it,is correct,????
- tuna
Correct. Just because a part number is for a specific model doesn't mean it doesn't fit other models. The only way to know if it fits other models is to have a good parts manual from a dealer or a wholesale distributor.
Remember too, the 914 was supposed to be the Type 4 sports car, utilizing the same engine as the 411. In Europe it was sold as a VW/Porsche car. You'll find a lot of common parts between the Type 4 series and the 914.
Tuna
Tuna
And sometimes (rarely) the system breaks down completely. For example, the Type IV CV joints have a 113 number, as does the hockey stick for a `60-`67 bus...a `66 bus has a 131 distributor. To the best of my knowledge none of these parts was ever used on a Type I (well, the Thing got the CV joints but that was after the 411). I guess it's safe to say that the part number indicates what type of vehicle they originally had the part in mind for, even if it never got it in production.
