condensor ?
Guest
condensor ?
Here's a newbie question. What does the condensor do anyway. my compufire points replacement went out and I put the points back in without the condensor. Engine runs fine.
- Speedy Jim
Very briefly:
Without the condensor, the spark will be weaker; may not start reliably and will mis-fire under load.
Also, the points will wear out very rapidly.
http://home.earthlink.net/~jimlux/hv/igncoil.htm
has some info first few paragraphs.
Speedy Jim
http://www.nls.net/mp/volks/
Speedy Jim
Guest
Guest
The condenser (capacitor) is a vital part of the Kettering ignition system. Without one, not only will the points degrade rapidly but the spark will be of very poor quality - possibly enough to make the engine run at low RPM but not well. In "electronic" systems which only rely upon the points to provide a trigger signal which controls the coil current (as opposed to the coil current having to actually pass thriough them) the condenser is not as important.
http://ourworld.compuserve.com/homepage ... n/CDI.HTML
