Any transmission oil/engine performance relationship?
sagaboy
Post by sagaboy »
I was using 140 wt transmission oil but changed it to 75/90 synthetic yesterday, went for a spin and noticed that….
1. Engine idle speed went up from 850 to 1,050 (200 rpm more)
2. My usual morning start-up with my disarmed carb auto-choke required an initial slight press of the gas for 15 seconds before the engine can rough idle without cutting-out—but with the new 75/90 tranny oil—7 seconds is sufficient and hardly any noticeable rough engine idling thereafter.
3. A vast improvement with acceleration--from experience—the improvement got to be at least 6% --a threshold before anyone can perceive/feel any improvement.
4. I told my next door mechanic about it and he said; “75/90? Hey, that’s pretty low for a transmission” … I replied, that’s what multi-grade are all about isn’t it? They are supposed to work that way 75 when cold and 90 during operating temperature—he (mechanic) kept quite.
Is everything a figment of imagination or real?—Need some confirmations, thanks.
rcb78
Post by rcb78 »
Good God, what the hell is wrong with you. Did you not read any of the replies in your post about tranny oil weight? Everyone, EVERYONE told you that the 140wt was too heavy and to use a good 75w-90. Do you maybe think now you can start listening and stop trying to rebut any and all help that is given to you? --Ryan
Guest
Post by Guest »
Keep running that post count up SAGABOY. You'll hit the record sooner or later. :lol:
sagaboy
Post by sagaboy »
Ryan... that was a different case--my previous half-dead tranny was making so much noise--hence the 140wt oil--hoping to cure it.
Finally I got it replaced with a rebuilt and that under tree repair guy insist on using 140wt oil--but I was thinking it (tranny oil) got to be changed after a certain run-in mileage anyway--see I did listen to you guys and changed it right, relax... everyone's tutoring have not gone to waste :o)
All I can say is that shifting gears with 140wt tranny oil is shi#%!*# compared with 75/90 synthetic--not mentioning other benefits-- Hence the question… Any relationship between transmission oil and engine performance?
Post by Marc »
sagaboy wrote:...Any relationship between transmission oil and engine performance?
Obviously there is, as you've witnessed first-hand.
What's the problem, you've been dreaming up imaginary symptoms and correlations for so long that you can't recognize a real one when it hits you in the face?
rcb78
Post by rcb78 »
It doesn't matter what the case was, you were told by everyone that there was no need for such a heavy oil regardless, unless you had serious other issues that needed attention first. --Ryan
rcb78
Post by rcb78 »
Why don't you go and re-read your own post. I only see one post that said to use 140wt if you wanted to, but only because the tranny was junk and it didn't matter anyways. How could you interpret this one post to hold true for a newly rebuilt tranny and take precedence over everyone else's advice? --Ryan
http://www.shoptalkforums.com/viewtopic ... t=gear+oil
I personally like this part
sagaboy wrote:100% confirmed that 140 wt transmission oil is correct for warm/hot countries with daily temperature above 28C.
500LbGorilla
Post by 500LbGorilla »
Sagaboy, use the red stuff.. it's faster.
