Ebayer Muffler
Longbeach412
That is a damper type...or mid exit...I think. I can't read German...but that word in the expanded view of the tag...appears to be something..."damper". The mid exit is called a damper type muffler. It might also explain why they didn't show the other side of the muffler....as unless it comes with the pipe...or you have one already...then you are SOL.....as they are generally unavailable. But...Leistritz is an excellent brand. Ray
Longbeach412
Longbeach412
Longbeach412
The real problem with fabricating the tail pipe....is the little details. It actually had a reduced diameter end piece with a slight bend in it (to make it lay flay along the muffler body)...that inserted into the hole. It then had a ceramic type sealing ring.....and a tab type clamp....much like a distributor clamp. An 8mm bolt goes through the hole in the metal tab welded to the pipe....and screws into a nut welded into the muffler body....locking it down. The other end of the tail pipe...has another tab that locks it down to the muffler in the same way. Thats why the pipe for the left or right , damper style exit are different. The tabs are reversed.
Hardware kits with sealing ring are easy to find...just not the pipe itself. Any decent muffler shop...with a hydraulic expander/swager/bender unit....could easily and quickly fab up a quick pipe with the slight bend...and then swge it to reduce to hole size...then tack weld on a couple strips of 1/8 steel for the tabs. I suspecy....it would cost about $45. The pipe itself...generally ran about $30+. Ray
Guest
vwbill
Fab it into a duali look!
Hey have them fab the end to match the exit hole and tee it into two tips and put chromey ends on it,lol! Fakey dual pipes! Probably not worth the work though to do that! Bill
- MGVWfan
