I was just wondering the pro's and con's of each. Here is what I have so far:
Flow Through - Easier to make, easy on carbs, easier to run high pressure.
Blow Through - More power?, Better mpg?
Flow through or Blow through?
vw@micron.net
Most suck through systems that I have seen stick out from the engine compartment so forget closing the decklid. The blow through could allow a hide-away system.
- Sharkey
There's quite a lot of info regarding the differences between the two, but to keep things brief:
PROs of suck thru system (on an ACVW): utilizes stock intake system, fuel pump, and almost any carburetor; simpler construction; cheaper; used kits readily available; no BOV (blow-off valve) required
CONs of suck thru system: turbo is located in the engine compartment (which translates into a LOT of extra heat); can't be intercooled easily; suffers from icing below 50 degrees F
PROs of blow thru system: much easier to intercool; no icing; better throttle response; lower emissions; ideal for EFI cars
CONs of blow thru system: usually more expensive, even when compared to new suck thru systems; high pressure fuel delivery system required
- dcatts
If there are kits readily available where do I find one? Also how much should I expect to pay ?
dan
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by Sharkey:
<B>There's quite a lot of info regarding the differences between the two, but to keep things brief:
CONs of blow thru system: usually more expensive, even when compared to new suck thru systems; high pressure fuel delivery system required</B><HR></BLOCKQUOTE>
dan
- Sharkey
KRE, Turbo City, and Bernie Bergmann still make suck through kits for Bugs, but decklid stand-offs are usually required. These systems require a carb, which usually isn't included (due to their scarcity).
Turbo City, CB Performance, Fischer Engineering, and Bernie Bergmann sell blow thru systems (the first two being available only in EFI versions nowadays).
As for price... hold on to your hat. A *complete* EFI turbo kit from CB Performance starts at $3,000 US. If you are serious about going *that* route, visit my website for pros and cons of the ACVW EFI world.
