I haven't figured it out. How do you use the boxes for italics, bold, etc. and how do you post a link to another thread. I tried the URL box but it just prints the words with [url] front and back.
Ron
Using Message body tool bar
- sideshow
Just play around;
but use the preview button to check on your work.
The fastest way I have found is;
Now the links to others are a little tricky, but it is the same idea. I copy the URL from the browsers address bar, and do the same blocking to add the image tag.
Here is a SSC tranny;
- write what you want first
ignore any formating
then go back and block (using the mouse, click and drag)
when blocked click on the the style
