affect of tilting front beam foward?
Chris in Ohio
Post by Chris in Ohio »
I'm building a street rail that is powered by a GSXR 750 motor. Any way, I want to adapt a 73 type 1 standard front end to this thing, but, if I do it the easy way, the top beam is out an inch and a half past the lower beam, leaning forward. Will this have ill affects on my suspension and handling? The car will be about 1100 pounds and have about 50/50 weight distribution. Any thoughts will be appreciated.
Thanks,
Chris
TWD
Post by TWD »
http://www.familycar.com/alignment.htm
Very squirrelly like that.
Chris in Ohio
Thank you for that info. I'm not the sharpest tool in the shead when it comes to steering. I kinda thought I'd have to not be lazy on this one.
Thanks again,
Chris
Bear1l
Post by Bear1l »
This is from a different thread about steering.
vicsvw Joined: 06 Mar 2001
Posts: 948 Location: Buckner Mo.
Posted: Sun Sep 04, 2005 10:52 am
Small Wing works OK But can cause Breaking problems and check the front end Toe in. About 1/8" toe in and if it's for the street, Plenty of caster. About 1/2" to 3/4" lay back. (Drop a plumb bob touching the lower front axel beam and make the top Beam "torsion tube" .5" to .750" behind the lower tube. Remember the larger the rear tires the less caster you will have.
Chris in Ohio
Oh sure Bear, thanks, Why do all the things that would be easy ALWAYS have to be opposite of what you are trying to accomplish! :evil: Who is this Murphy and how did he pass that law?
Chris
Bear1l
Post by Bear1l »
Glad I could help :arrow: Why is it that these things are never as bad when they happen to someone else :wink:
gcorrado
Post by gcorrado »
yeah, you MUST have some caster. if the top of the beam is ahead of the bottom of the beam you will be really damn sorry...
