Road Racing takes a toll
rsrnate
The bug finally blew up,after three hard years of race abuse.I was at Buttonwillow coming out of cotton corners at the top of third gear and just before it hit 7,000 rpm BAM it let go
I coasted off the track in a cloud of smoke. There is oil all over the place and I pulled out a chunk of magnesiem out of the 1&2 side rocker box so its going to be bad. I will pull the motor out when i get home.
Pablo
We used to use this sort of rod to minimize damage, in the event one "let go". Good to 150hp per rod (600 hp). If they break, they will shatter into bits, rather than blowing a hole through the case.
http://www.thesamba.com/vw/forum/album_ ... _id=232227
Chris V
http://www.joesracing.com/
Son of Marc
Son of Marc
rsrnate
The finall score is two holes in the case,mangled crank two smashed rods three completely destroyed pistons and cylinders, cam is in two pieces,four bashed lifters and three bent pushrods and both heads have cracks.
It is a real mess but i think that i had a rod bolt failer.The #1 rod is the one that let go I found the streched and mangled cap and it still had the bolts in it. I had scat I beams and a conter weighted crank, the motor did not smoke or use oil and the endplay is still good
