Carburator rebuildable or not?
Guest
Post by Guest »
Hi just tried to crank up the old ghia after it has been setting for awhile, I know not a good idea to let a car set for awhile. I got the car to run but seemed like it was running on 2 cyclinders, then finally it quit running. I went around back and was looking at the engine and noticed the carburator was leaking around the accelerator shaft [not sure if this what its correct name is?] on the right side of the carb. This was late at night and i havent got a chance to take a closer look at it since i work 12hr days,but if it is leaking out the shaft is this repairable? If so what would be involved in the repair of this carb. Friend at work said it might need to be brassened?
I guess it would help if i mention what carb it is, *shakes head* duh its a 34 PICT/3 Carburetor.
Speedy Jim
Post by Speedy Jim »
Fuel leaking may mean the float needle valve is not closing.
Engine will flood and stall.
Take top of carb off (5 screws).
Carb info:
http://www.vw-resource.com/carb.html#carburetor
Speedy Jim
http://www.nls.net/mp/volks/
Guest
Post by Guest »
Thanks Speedy will give it a shot. After reading for almost 4 hrs I was begininng to wonder if the float could be hanging up. I hope this is what it is.
Thanks Barry
vicsvw
Rebuildable ?
Post by vicsvw »
Pull the throttle shaft down 1/2 way and push & Pull if there is slop it's time to buy a new carb. They can be repaired but most of the time it's cheaper to get a new one. See -> Solex Carb Throttle Shaft rebushing <> http://www.1800vw.bizhosting.com/qa_carb_rebushing.htm If your carb has the plastic bushings then by all means rebuild it. "Solex carbs are an organized Leak" and a great one at that. Vic.
Guest
Post by Guest »
HI vicsvw
I just got through checking the side to side movement in the carb, the throttle shaft doesnt have much movement at all. I guess I will be checking the float next. Monday I will be getting a rebuild kit and rebuilding it . I hope.
Barry
Guest
Post by Guest »
hi.
newbie back again.....just a quick question
I was wondering if all carb rebuilt kits are basically the same?
I can get one at advanceauto, but is as good as quality as one that i can get at a foreignauto parts store?
thanks guys and gals
