Anyone have a thermostat PLEASE???
- MGVWfan
Man, I've been BO'd for months and cancelled outright on ACVW thermostats ordered from 4 different places now. Anyone have a non-leaky stat they'd be willing to part with for my 412? I've got everything else, just not the stat. And I've given up on the solenoid idea, the forces required are just too big for any reasonably sized solenoid to deal with.
Lane
67 MGB (Abingdon's Finest)
04 Golf TDI (45 MPG)
hoodsy
Well I don't know if it is of any use to you, but I have a couple of those around but I think they all need a new piece of wire attached to them, but the bellows itself should be okay. around here most people cut the wires on them and run without them.I will see if I can come across any that haven't been cut.
albert
thermostat
hi, mg, for your thermostat he have many solution,, on the maket you can find type 1 or type2 thermostat for appx.35$ with small modification on the therm.wire take the most hight therm. if you want to go with électric therm. and sélénoild . use the starter sélénoild ( you can use any ,,vw,, sélénoild . with hook, but you put 1of the 2 small therminal on the starter on the ground ,,, inside the sélénoild you have 2 windding ,, 1 for to start ,and 1 for to keed ,,on,, and that make a very strong thing ,alb.
- MGVWfan
Hey Hoodsy, I've PM'ed you, thanks.
Albert, bon jour! I've considered a starter solenoid, but they pull way too much current (15-20A for the holding coil, 30-50A for the pull-in coil) and aren't designed to be energized for more than a minute or so continuously due to heating effects. But, the pull of a starter solenoid pull-in coil is what I need for this application, true enough. Thanks for the reply.
Lane
albert
thermostat
hi, mg, do you thing , at the vaccumm cruze controle for the modern car today with this équipment ,, you have a big diaframg on the gaz wire who geeve action by vaccuum on this cable ,, put only small électric air sélénoild , you can find all that on the audi 5000 and you connect that on small électric thermostat and wend the thermostat geeve the power on the sélénoild , the vaccumm from the motor head make suction on the diaframg and keep the mécanic door flap open,,, that is only one suggestion ,,,albert
albert
thermostat
hi,bil, yes , the heather controle box is good idée too, but it is make with plastic , and at my oppignion ,it is not very strong for to work on the 412 cooling door damper , and on the audi cruise controle, the vaccuumm dyafrram is strong with long road for action , d,t use the vaccumm audi motor for cruse controle , use only the 412 head vaccumm , more simple,,, the choke cable is very good ,but you never know wend the motor is at the good temp but more simple ,alb.
- MGVWfan
My boss and I were talking about this today...we had exactly the same idea, a modern cruise control servo, the kind with just the vacuum can and solenoid valves, no speedometer cable connection. It could work.
Another thought...a Corvair thermostat?
http://www.corvair.com/user-cgi/catalog ... IN&page=20
see the bottom of the page, and...
http://www.corvair.com/user-cgi/catalog ... N&page=106
Lane
albert
thermostat
hi,,, mgvw ,, you can buy a new thermostat , on ,,,busdepot .com ,,, take the good year for your 412 ,,, same year type2 and same cc motor ,,,, the parts no.is ,,, 111 119 159 agr for the nice usa$ 54.95$ i look your corvair car thermostat he look same model but he have the same degrées fr. randge ,, examp. open at 180 and close at 50 ,, look the 412 reférence and corvair refference for comparaison ,, if you can buy new from busdepot ,, it is the best , it is made for vw ,,,albert
- MGVWfan
Bus Depot is now out of any variety of ACVW thermostats, unfortunately. I checked them last week.
Lane
albert
thermostat
i find , secon place for you,,, pélican porche parts,,, po.no. 021-119-159 a ,,oem at the nice spécial price of,,,,83.50$ or try ,,, cip,,,
- MGVWfan
CIP is out of stock also (tried them a month ago), haven't tried Pelican Parts, but that price, yeow!
The problem is that Wahler has stopped making new thermostats, and the NOS is drying up fast.
If that 'Vair stat works for T4s, it opens up a different line of supply that's still in production...and 'Vair fans appear to want to keep the thermostat in there, which makes for a market for new 'stats into the future.
Lane
albert
thermostat
hi , mg , i look for you on cip,,, the original is out of stock but he have replacement thermostat ,,, look on cip page no. 53 parts no. vwc-043-119-159 at 40.$ and i look for you in my tech book ( spécial albert ) the degrées.fr. for original 412 thermostat is 85 deg.cel. appx. 175 d.f.
albert
thermostat
and i see on my dailay job ,, pilot flame sensor for gaz stove ,, with this pilot sensor you can find 10 différent degrées or lenth of the push road from 4" to 28" ,, this kind of thermostat , détect the pilot flame , and he close the main pipe for the gaz if he d,t have fire on the pilot ,, the moovement of the road is appx. 1to 2"
- MGVWfan
I just ordered from German Auto Parts, we'll see if they really have one in stock...
Lane
