NOS Koni adjustable strut cartridges
Changed to an excentric strut bearing
New center link
New ball joint boots, plus added grease fittings to the joints
New tie rod end boots.
Custom idler arm bushing, greasable
New seals in steering box
"T" assembly and lower suspension arms off of a '74 square that appears to have had all the rubber recently replaced including the grommet like piece on the radius arm.
Sway bar off of '74 square that is about 60 thousanths larger in dia. than the old one on my '72
Phosphoric acid treatment on the fuel tank, plus all new hoses, and sending unit
New battery
Custom rebuilt front seats
NOS master cylinder
I still have lots of things to do, like trouble shooting the gas heater, but it is a fine driving car once again.
I still however have questionable brakes which I will bring up in another post.
