Car: '70 bug with 4 bolt trailing arm to spring plate attachment
Modifications: lowered 2.5" with 944 torsion bars
Problem: excessive camber (about 3 degrees), want 1-2 degrees; adding sway-away adjustable spring plates and need clarification on how to mount and modify the spring plate slots to reduce camber
Questions:
1. The sway-away adjustable spring plate has 3 slots and my trailing arm has 4 holes. The extra hole is toward the front and is threaded. Should I drill an extra hole in the spring plate, or just use the three bolts for mounting? Is the later model 3 hole trailing arm easier to adjust than the 4 hole? I'm planning on using just the 3 holes. Correct?
2. To de-camber, I'm planning on removing material from the tops of the two rear slots in the spring plate so the trailing arm can be rotated with respect to the spring plate about the front hole in the 3 hole triangle pattern. Correct? How much material should I remove? 0.05", 0.10"? I'm planning on enlarging the slot the same amount front to back along the top side of the slot only, for just the two rear slots.
Thanks for the help.
Bill
IRS Camber
mudman
Other than aftermarket arm's Might want to swap arm's from side to side. I was told this help's with the camber issue's but will need to modify the shock mount. I really do not know if this is true, just what I was told.
If you can run aftermarket arm's, I know a guy that can build you a set to the speck's you want/need. He sell's the offroad arm's for about $350.00 a pair and can use the T-1 or the T-2 stub and bearing housing.
Mike
Mike
- Kafer_Mike
Re: IRS Camber
I had the same concern when installing Sway-A-Way adjustable spring plates on my '69 Beetle. Per SAW, you only need to use the 3 holes...Bill K. wrote:Questions:
"Build 'em fast...or let 'em sit"
Bruce2
- Bill K.
