911 Front Struts
- Bill K.
911 Front Struts
914'ers upgrade to 5-lug and better brakes by swapping to the 911 strut asssembly, can '73 412 do the same? ...swap 911 strut assembly?
- Bill K.
Maybe the lower spring perch of the 412 could be welded to the 911 strut tube (with spindle needed for caliper and hub mounting). Porsche strut inserts?, 412 coils, 412 assymetric strut mounts. 911 ball joints... 911 spindle can be relocated on strut tube as necessary. Just an idea. Need to do some measuring... Other worries too, I'm sure...
- Wally
Hi Bill,
As I wrote you on Germanlook.com, there is somebody on the 914club.com forum that has the disk of the early 914 made for 5-bolt...
As you may know, the disk of the early 914 is the same as the 412's.
Not sure if early porsche S-calipers fit in the same location as stock 412/914 calipers.
Regards,
Walter
Regards,
Walter
- ubercrap
Right, if one just wants the Porsche 5x130 bolt pattern in the front and better calipers, that is a a bolt on affair. Is place/person you were thinking of Wally?
http://www.914club.com/bbs2/index.php?a ... ntry359306
Then, you could probably do the BMW E21 320i caliper swap the 914 guys do. See the Pelican Parts website for details. Then, you would have moderately upgraded brakes and the Porsche 5 bolt pattern, with no big hassle.
- Wally
- Wally
Billet Hubs? Cool! Tell me more, please! What, where, how muchBleyseng wrote:I imagine that you can use the billet 914 hubs and mount vented 911 discs and also mount spaced Carrera Calipers on. That would give you killer front brakes.
Geoff
Are they also available for the old 914 model (=411/412) until 914 mid '72?
TIA,
Walter
Relocating the 911 spindle to the 412....of course can be done. Of course the ball joints must come also. The 911 cartridges will trash the 412 ball joint in a day. Main problems will be that the 911 cartridge is nowhere near the shape and size needed to run in a 412. You really really need to look carefully at the architecture of the 411/412. Also.....in what respect is anyone sure that the 911 strut valving would do anything positive for the 411/412? Especially without the same weight ratio on top of it...or the same spring rates, bushing rates and design...etc.
Other than having 5 bolts hubs to use different wheels....I'm not sure what benefit there would be to using 911 parts. Ray
- Bill K.
I had in mind two benefits to the 911 spindles -- 1) 911 ball joints are available, 2) lots of bolt-on ventilated disk options. But, a modified 944 hub (with inserts for T1 bearings) can give the ventilated disk option and rebuilding T4 ball joints is acceptable.
BTW, would the Audi 4000 cartridge fit in the 911 strut tube? Would the 412 lower spring perch fit on the 911 strut tube? ...911 spindle & ball joint with Audi 4000 cartridge and 412 springs...
- Wally
Ah, found them:Wally wrote:Billet Hubs? Cool! Tell me more, please! What, where, how muchBleyseng wrote:I imagine that you can use the billet 914 hubs and mount vented 911 discs and also mount spaced Carrera Calipers on. That would give you killer front brakes.
Geoff![]()
TIA,
Walter
http://www.914club.com/bbs2/index.php?act=ecCatalog
Unfortunately, it says that they only fit the late style (73-76) 914 axles...so they won't fit our 411/412's
Thanks for the suggestion tho.
- Wally
Hey Ray, the 911 strut was not my idea, I don't have any and I probably wouldn't go that route myself...
So, sorry, but can't help you there.
I WILL have another look at my 412 rear suspension, I can assure you that
- Wally
Yes, that makes sense, but what would the reason for the explicit warning on the 914club.com site be for? Caliper or strut interference? That may or may not be an issue on our 412's...
With those expensive parts, you don't want to take chances
Tnx,
Walter
Tnx,
Walter
