Valve adjustment
SA TYPE IV
Valve adjustment
wildthings
Yep...get a manual. But, there are some easier ways than what teh book says.
First take of the distributor cap. Put the car in neutral and turn the engine via the alternator.....so the rotor is moving counter clockwise. Bring the rotor around so that it is pointing to the notch on the distributor body. It should be pointing to teh 4 or 5 o lock position as you are looking at it. Pull the plastic plug from the hole in the cooling housing. If the little "0" is showing in the "V" notch in teh cooling housing....you are at TDC for #1. Adjust both the exhaust and intake on cylinder #1.
Now...still turning the engine so the rotor is moving counterclockwise...tuen until teh rotor has moved exactly 180 degrees from the notch on the distributor. That will be TDC for #2. Adjust both valves. Turn counterclockwise until the rotor is back on the notch on the distributor. That will be TDC for #3. Adjust both valves. Turn counterclockwise until the rotor moves back to the spot at 180 degrees fromn teh notch...where you adjusted #2. This will be #4. Adjust both valves.
This actually works best if you first take off the fan and make a mark exactly 180 degress from teh zero. Ray
- Wally
?? Shouldn't that read 90 degrees rotor movement instead of 180 ?you are at TDC for #1. Adjust both the exhaust and intake on cylinder #1.
When the engine turns 180 degrees, the rotor does 90 degrees to reach the next cylinder...
Or you probably meant 'the engine has moved exactly 180 degrees'
SA TYPE IV
SA TYPE IV
Well I guess a should'nt have crossed my fingers, tried to adjust valves but adjusters were just to worn or stripped out on #1 that I could'nt get them to turn even when I pulled the rocker off. I tried all others and had same problem. I'm going to let them soak and see if they break loose if not I'll be looking for some good used or new ones. Later guys.
