valve ajusment bolts
albert
hello, 412 fans ,,, pélican porsche parts ,,, sale a kind of valve bolts ajusment with swavel cone head ,, do try this kind of bolts before ,, they said me that fit in the roker arm on the 1700 cc and that geeve betther valve ajusment ,, thanks for your help ,,,albert
vwbill
I'm sure the 914 guys have a good setup for that stuff! Sounds like a good improvement probably over stock! That would be a good stick post for all the changes from stock that make a better performer and life of motor! Have to grab some of the 914 guys setup improvements! bill
I know Ray has lots of changes and improvements!!
albert
valve ajustment
thanks ,,ray ,,,for your help,,, i make reserche on the web and i see 3 model of this bolts ,,, in europe they name that ,,,éléphant foots ,, they look betther quality(picture from forum guy ) ??? i d,t know ,,,and i see one set in auto attlenta and one in pellican parts kataloge ,,, all the tree are différent ,,, but my question is wend the head is cover by a cone what you doo for to ajust your valve ,, you d,t have space for to pass a guage,,,
The only ones that are worthwhile quality are the genuine Porsche parts. The non-porsche swivel feet models are decent, but many of them suffer from poor metalurgy (ball snapping off) or poor tolerance (not enough swivel and too much slack). The type that uses an actual ball with a flat spot ground on the face of the ball....are generally beutifully made...but are absolute junk because there is not enough range to teh ball movement. It ALWAYS ends up cracking the edge of the cup and causing damage to othere things. Get the Porsche ones. They are worth the money. That is what Jake sells.
These parts are not "cones" or caps. They "should" have flat....but wide...ends. Valve adjustment is the same as normal with them. Ray
albert
valve ajusment
thanks ,,ray ,, yes that i thing to ,, the quality of the balljoint ,,, plus if the balljoint com down ,or brooke ,what katastrof in the motor ,,, i thing the model with flat surface from ,,attlenta auto parts,, is a good model ,, in europe they buy that from ,,scatt,, and they have a cone model over the valve shaft (end of the valve ) and pélican to ,,and in europe the guy said me we can install that only wend we install a new set of valve ,, not recommande on the old valve ,, thanks ,,albert
The cone type ones are ones are what we call "lash caps". They are to cover and correct the damage that commonly comes to stainless steel valves from running hardened adjuster screws. It wears a dent in teh end of the valves. They are a quick fix to extend lif of the valve. Some people install them on new valves if they do not use hardened stems and tips.
If you use the flat bottomed Porshe style swivel screws, you can use them as well on new non-hardened stainless valve because teh greater surface area keeps from eroding the valve stem tip. Ray
