Singlecab Brakes
- Advokat
Singlecab Brakes
Looking for suggestions for kits, if available, that will allow the front drums on a '68 Singlecab to be switched for discs.
- aircooledtechguy
- Advokat
Nate!!!!!!!!!!!! How are you doing, Man? How's life? Are you a full-fledged civilian now?
Anyway, I sold my Thing and I'm looking really hard at this truck. I knew about the '71 beam being a bolt-on affair, but it's slim pickings around here and I imagine shipping one from out west is big $$$. That's why I was wondering about an aftermarket kit.
Is it possible to just buy '71 brake-related components and just bolt them to the '68's front end?
As far as bolt patterns go, I don't really care that much as I figure I can correct any issue with wheel adaptors, if necessary.
Thanks guys,
Rick
Thanks guys,
Rick
Actually I don't think a `71 beam will bolt up directly in place of a `68 (at least not with all of the bolts, they're different at the mounting flanges) but the later spindles will fit in place of the drum-brake units.
You might want to go with `73-up stuff instead, the `71/`72-only is becoming obsolescent.
Bolt pattern is 5x112 (same as Benz); I've seen adaptors to mount 5x130 Porsche rims, but not 5x205.
Splitty and early (`68-early`70) bay beams have this mounting bolt pattern:
On later bay beams this measurement is 128mm. All the bay beams use the same control arms; spindles are `68-`70 drum, `71/`72 disc, or `73-`79 disc and will fit any balljoint front end. If there's any difference in ride height between bay drum & disc it's subtle.
Most folks who're running front discs with no power assist say that the pedal effort isn't too bad, so you probably won't need to worry about mounting/plumbing a servo.
- Advokat
I know that this is an old thread, but I recently read somewhere that it is possible to mount Porsche 944 calipers, rotors-hub assembly, etc. on the '68-'70 spindles.
Does anyone know if this is true? I would really like to know as I've just now started looking for parts to do the disc conversion and if I can avoid having to swap the spindles out, I'd just as soon consider that route.
Thanks,
Rick
Thanks,
Rick
Pillow
You are correct! The 944 brakes can be used on the front of the early bays just as easily as the splits.
A few vendors are now offering the kits for this.
Buy the 944 parts used and refurbish, then get all the custom stuff from a vendor. All in all a very affordable way to get great stoppong power and an easy easy conversion. 2 hours if you are good with a wrench, 4 if you take beer breaks
- Advokat
Okay. So I don't have to pay through the nose for one of those kits. My question then is, I guess, what do I source from the bone yard and what do I have to buy from the vendor?
My thought is that if I get the calipers, rotors and hub assembly from a junked Porsche, all I have to buy from a vendor are the caliper mounting brackets?
Thanks,
Rick
Thanks,
Rick
Pillow
IIRC All I needed was:
- Beetle rubber brake lines
- A bearing spacer for inside the 944 hub
- Modified grease caps.
- Custom caliper mount.
Really not much at all. The rest is stock 944 stuff which is not all that expensive.
The other new Porsche parts for rebuild I sourced through pelicanparts.com
- Advokat
Pillow:
Not to beat a dead horse, but I once had a Thing that I got a kit that let me use Ghia parts. The whole thing, from soup to nuts, cost like $200 and it was a direct bolt-on to the existing drum spindle. Plus, all of the Ghia components were brand spanking new.
Are you aware of any reason that this type of set up cannot be used on a Bus/Singlecab? By the way, where did you get the caliper bracket?
Thanks,
Rick
Thanks,
Rick
Pillow
