Cooling thermostat ??
vwbill
Post by vwbill »
Hey has anyone thought about the thermostat that controls the cooling warm up flaps? So in the bentley for the bus it says it should be 46mm expanded but what is the starting measurement? So basically the travel of the cable and thermostat. What about a screw type method of travel or is it just easier to get a used one at a yard? SHould the rod spring be removed? bill
albert
cooling thermostat
Post by albert »
hi, bill, i you want to pay ,,,65.$ for original or 35.$ for replacement , i know a place for to buy , and if you buy new take the model for 180dr.f. if my mémory is good , the parts no. finish by 165c i thing , and for to know if it is good or not , reemoove the thermostat and put in your home freezer for 2o minutes and afther you put in your home oven at 300dr.f. for 20m. and you mesure the distance , minimumm and maximum lenth ,, if he d,t moove it is good for garbadge ,,, alb.
vwbill
Post by vwbill »
Hi Albert, thanks for the reply!! Someone has original ones? I would like to get one fro sure! Thx Bill
albert
cooling thermostat
Post by albert »
bill go to see you ,,pm,,
vwbill
Post by vwbill »
Hey Albert, thanks for the thermostat info! Some of the info should be posted and some in the sticky post! Thanks again Bill
albert
cooling thermostat
Post by albert »
hi, bill , i am happy , if my info, geeve you satisfaction, send on the forum if you want ,alb.
mrbaja
Post by mrbaja »
I got a question along the same lines here. I had to disconnect the thermostat cable when I took my fanshroud off to remove the oil cooler and change the oil cooler seals.
What's the "preload" for the thermostat? In other words, what's the proper way of setting up the thermostat?
Aloha, Theo
There is no real preload setting...but its not hard to get the hang of.
If you are still using teh stock cast aluminum cooling shroud...VW made teh adjustment quite easy on this cable.....and it took me years to notice it.
First thing. The engine should be stone cold and the thermostat bellows must be contracted. Check the measurement with the book to be sure.
Thread the cable up through the shroud.
Make sure teh spring is installed on the cross shaft correctly....and that the little spring hold down plate is installed under the screw.
NOTE: Bear in mind that the spring is designed to hold the flaps open. When cold, teh bellows holds them closed. So when the spring is installed correctly...the little lever with the locking screw pops toward the back of the car.
Here is the neat part. Push teh lever toward the front of the car until it stops moving....that is flaps closed. You can feel the spring tension. Now hold it there. Put your eyes on the cross shaft bar....follow it with your eyes....toward the distributor to your left. You will come to an area of the cross shaft that has a "cranked" portion in it. Take a large plat screwdriver....a crescent wrench....or a piece of wood....and wedge it between teh cranked area and the cooling manifold casting. The flap bar will now stay in the closed position while you use both hands to put moderate tension on the cable...and tighten the clamp screw.
The object is ...to not stretch teh bellows more than about 2mm. Also....likewise....when you pull the wedge out....the arm where the cable is clamped should not pull toward the rear...more than 2-3mm. Ray
mrbaja
Post by mrbaja »
Got it set! I knew there was something easy to set it up. Thanks Ray :D
Aloha, Theo
