trying to find what timing my t4 AN engine should be set at? got it running at 7.5 deg btdc i think but lack of markings makes it hard to be shure!
starts ok ish but ticksover realy high when warm then runs on when the ignition is switched off!
an series timing woes?
- Wally
Yeah, I agree with Ray.raygreenwood wrote:7.5 should be fine. In general...if your idle cut-off jet is working properly...it should not be possibel to run on...no matter what the timing. Ray
Mine is an AN engine as well.
Most - no, make that ALL - 412 engines have at least the idle timing mark visable through a big black plug on top of the magnesium airflow-housing.
Some even have a timing mark for max advance (without vacuum), which is around 27 degrees BTDC..
Do NOT set timing accidently at the max advance mark. Strangely enough, it is even possible to let it run at idle (somewhat) at that mark if you really try....
