madmike wrote: ↑Fri Jan 19, 2018 3:14 am
That's a nice clean break for sure I've seen them crack but not completely off damn
Gusset's look like they will do the job
Even with clutch management it just couldn’t hold the pinion in the case.
New box will be as stout as a T1 box can be
Boost was created only to make people smile, and make power!
Chip Birks wrote: ↑Fri Jan 19, 2018 8:33 am
Glad to see you updating this thread with the new info. Still gonna run a decklid, or has that been given up on in effort to get that 9 sec slip?
Does a decklid make a big difference at that speed?
Due to weight or aerodynamically?
My guess is that neither plays a big difference..
As you can see in the photo, the pipe going in to the plenums are not centered...
Next time I will weld the 90 degree onto the plenum and the 3/4 side is almost done. the last stage will be to close the plenums, and will do both sides at the same time.
