flycutting for compression ratio
Re: flycutting for compression ration
you like livin on the edge,LOL
- Devastator
Any competent machine shop should also be able to deck the heads.....Max Welton wrote:Why not have the cylinders cut down to reduce deck? Any competent machine-shop should be able to do that.
Devastator's Build Thread
Sandrail
going fast enough."
Mario Andretti
Sandrail
going fast enough."
Mario Andretti
- Max Welton
True. And to get the rest of the way to 8.5 he will still need a little flycut anyway.
Max
Max
Ding Ding Ding we have a winner !!!! Just flycut the heads. I do like the idea of putting all the CC's of fluid ( I use tinted rubbing alcohol) you need into the chamber of the head and marking or measureing it to get a fairly precise number for the flycut. Mike McCarthy
.050-.055" deck is a sensible figure with a large bore (the bigger the bore, the more the piston-to-head clearance is reduced by the same amount of piston rock - and any increased piston-to-cylinder clearance allows even more rock). Even with a stock bore, .040" is pushing your luck. Missed shifts happen.
As for shortening the barrels...it would only make sense if you couldn't achieve your ends by decking the case and/or flycutting the heads - otherwise, it's just one more "custom" component that'll need to be duplicated should you ever need to replace one for some reason.
I'm more conservative when it comes to street C.R. than arnolds64, I encourage you to stay with your plan and shoot for 8.5:1. Have you done any mockup to see what your valve-to-piston clearance looks like? With flattop pistons you'll need to flycut the heads ~.070" for 8½, so you're going to want to see at least .160" clearance with the heads as they are right now (.190" would be better, at least for the exhaust). That'll give you ~.090" or more clearance after the heads are cut.
Clearance is at its minimum as the piston approaches TDC on the exhaust stroke; should you ever want to experiment with advancing the cam timing that'll reduce the intake clearance, so IMO it's wise to make the check with the cam advanced a couple of degrees even if you plan to install it straight-up. If you end up needing to mill any valve reliefs out of the piston tops they'll drop the C.R. slightly so more flycut will be needed to compensate.
Probably not a concern on this mild of an engine, but perhaps worth mentioning for someone reading this thread in the future:
Note that as the heads are cut or the piston deck height is increased, the valve contact points move "up" on the piston. If you mark the locations for valve notches before the heads are cut, the notches end up low which gives less gain in clearance for a given depth (and C.R. reduction).
- John S.
Anyone know where to get cutting blades for a GB fly cutter. Their 1/4x1/2x1.250 approximately. Everything I find is 4” long. GB has them for $36. Just looking for cheaper and fast.
Buy the 4” long piece. It’s easy to cut with an abrasive wheel. I. Usually score each side leaving a little meat in the middle and snap it off and grind your clearance angles.
- John S.
Thanks. That was my plan. As of now, I sharpened my blade and it works fine.
Myself I would level the heads and pour however many cc's you need into the chamber and use a depth indicator to measure from the deck to the top of your liquid , take that number and cut it to that depth . Doing it this way it will be as near exact as possible and the shape of the chamber will not effect the results.
I would run 9:1 minimum with that cam. I've been running a 94x78,4 with fk8 all last season set at about 9.1:1 and it ran great. Have the heads fly cut to get your desired compression and you'll be good to go.
