Needed a new separation panel, the one between the back of the cab and the bed. Mine was smashed from items being loaded in the bed and rusted away.
I could buy one so I made one in a 10 ton press. I made a form to stamp the metal to using strips of aluminum.
Made a test piece to make sure it made the shape correctly.
Needed inner ribs for the rear rockers in the back right. Another part not available. So tried my hand at forming it with a wood form. It worked, but I could use a metal shrinker.
It was installed inside these rockers. Then welded the new rocker in. Forgot to take pics as I went on this one.
Next I had to fix extensive rust in the upper windshield posts and under the roof edge. Kind of a odd spot for rust. I strapped the posts initially cause I didn't know if they would sag once they were cut. Found nothing moved when I cut them.
Sand Blasted the inside of the remaining roof sections. This is before welding the inside panels back in.
Alot of work happen to get here, just too busy to take a bunch of pics
The side of the truck doesn't look too bad in the pic, but its really wavy from heating it too much when it was installed. It looks like the truck was in an accident. The section replaced behind the door was repaired but had 3/4" of bondo to make it look right. Decided to just cut out the warped sections and redo it.
New Gerson panel
OF course, the two repair panels were not big enough to meet.
Had to keep fitting the door, to make sure they end up in the right spot.
So I had repaired one gate but have two more to take apart and fix. I was putting this job off cause it was a lot of work but the other two weren't as badly damaged as that first one.
Checking the fit.
It needed a little work to fit better, was too tight caused it to preload.
Had to find some temporary wheels and tires cause I changed the lug pattern to Ford 5 lug. And havn't found my new wheels yet. Got these for $50
When I had the front floor out, I raised the steering box 1.3", didn't take any pics of that. But now the pedal levers hit the steering box. So had to modify them a little to make them operate properly.
My nose repair parts came in. So I started cutting the nose apart. Used tape to make a nice straight line.
The outer skin, inner panel and bumper support are rotted away. So need to open it up to get at all the damage.
Some of the things I found in the nose.
Door hinge nut plates were toast, so made some new ones
The nose panel didn't fit correct, may be a Double Cab thing. Sectioned my new panel to make it the same shape as the old one.
This corner turned out to be a real pain in the butt
Good time to fit a new battery tray
Used metal off an old filing cabinet. lol
Restore the fuel tank. Sand Blasted this, then used a tank sealer kit.
Packed up the spindles to get flipped. This will lower the front 3.5"
Got a new 2" narrowed CB Performance Beam. I need it 4" narrowed. This is an easy way to do it.
Made this tool to pull the bearings without damaging them.
This goes in past the outer bearing, this is inserted to drive the inner bearing an inch in
This is how it needs to be positioned on the inner bearing to drive it down
Then drive the outer bearing in an inch
Then cut the one inch boss off the outer edge of the beam
