While I had the spice rack on the drivers side removed it seemed like the right time to remove the curtain track on the passengers side to install the speaker and rear wiper harness I had pulled out of my parts van to clean up the wiring in preparation for a stereo upgrade and adding in front speakers. I also had to pull the front head liner to access the top of the A pillar and along the way I discovered another large rodents nest and likely the source of the smell when it sits out in the sun.
Once I found that nest I decided the insulation over the cab was trash so I pulled it out
so after removing a whole bunch of the interior I pulled a wire up the A pillar and snaked the stock harness up and pulled it all the way back to the rear cabinet for the speakers I don't have many pictures of this process as I worked alone and just kept working but now I have factory speaker wires for the rear speakers rather than the wires my father ran through the kitchen for my grandparents
And since I had the headliner out it was the right time to pull the luggage rack from the top to clean under it and add screens to the drains, this is what I found when the luggage rack came off:
I cleaned the roof and forgot to grab a picture but I did get a picture of the screens I used, I wanted screens with a dome to allow some junk to get up there and still let water drain between cleaning.
I used some super Glue to gold the rubber gasket to the bottom of the fiberglass:
pushing them up from the bottom:
there is a bit of the dome sticking out the top:
All screens installed
Finally getting the luggage rack back up on the roof.
After getting the luggage rack all installed it was time to install the reflexit insulation I bought to replace the removed roof insulation and used a good coat of supper 77 applied to both the roof and a heavy coat applied to the insulation and stuck it in place
then finished re installing the interior now no one can tell any difference except when the light is on though the smell should be better.
