Dropped spindles/adjustble beam ??
I have a 65 Single Cab that I am looking to lower. I am not familiar with the suspension on a bus or a single cab if they are the same? I like your the lok of your bus Rizz and am looking for a similar look. How do you find the ride? I am also interested in an air bag set up. I have seen a couple from John Jones and liked the idea of an adjustable ride. How do you think the ride would be between either set up.
I've found a place in australia called custom bugs and buses who make 2" drop spindles for ball joint bus front beam. Sounds like a perfect solution for fitting 68-70 front beam into pre67 bus. Here is the link.
http://www.cbbvw.com/index2.html
Has anyone heard of this company?
Michael
Michael
ya the only reason to narrow a front end is tire clearance. its alot of work and im not really interested in doing any bus beams for people but try franklins vw werks in washington. im not sure of the web address but im sure if you search the name you will find it.
Thanks for the info!
Ryan
Ryan
WOW! Great lead man! I emailed them looking for more info on the dropped balljoint spindles. Hope it pans out. As far as I know they'd be the only supplier of these. I'd definatly consider a set myself.
I'll post what I find out. Dropped spindles is definatly the way to go. And with the balljoint beam with disc brakes...I'd be setup!
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by rizzag11:
it has a 4 inch narrowed, adjustable beam with dropped spindles(all i made)
<HR></BLOCKQUOTE>
Jeff,
I've talked to Nate down in Salem who does some of the same stuff, but I never asked this question - Why narrow the front-end? Is it just for better tire clearance and fitting wider tires? And, what do you charge to narrow a front-end?
Thanks,
Ryan
in Portland, OR
<HR></BLOCKQUOTE>
Jeff,
Thanks,
Ryan
in Portland, OR
Here's the response I got:
Hi Rex
Yes you did read correctly we do do drop spindles for bus spidles they drop
2 1/4 inch and are on the spliter called Hamerd on our web site. As for the
cut and turn, that would not be my choice but hay it will work, the
adjusters would be my choice.
The spindles cost $770.00 aus dollars and we sell the adjusters for $89.00ea
aus dollars to suit type 2 beams.
Sorry I cant elaborate on this as I am leaving for a race meet tonight If
you have any other questions please drop another email.
MIKE
CBB Volkswagen
So that's $49 each for the adjusters and about $430 for the spindles. That's a lot of $$$ for dropped spindles...but remember that these are balljoint bus dropped spindles that I don't think anyone else makes. Good info for sure.
Hi Rex
MIKE
CBB Volkswagen
Rizz, that sounds like an opportunity to me! I cannot imagine that the bay spindles are harder to do than the split ones..?
Type2, put some M-B rims on there and it will look really nice.
Adrian Pillow
'66 VW Westfalia - "Biscuit"
'67 VW Deluxe Westfakia - "Dino" - FS
Adrian Pillow
Yeah, cbb is expensive alright. I find the link rizzag11 mentioned about and they have ball joint bus dropped spindles for as well. Dunno if they will fit on normal bus beams cuz the pictures shows a custom narrowed beam.
http://www.franklinsvwwerks.com/html/ourwork.htm
Michael
Michael
Rizz, you have mail
Adrian Pillow
Adrian Pillow
- Plasticfantastic
Does EVERYBODY up that way do this .... ??? http://www.thesamba.com/vw/classifieds/ ... 1018188939
FYI - here is some more of his stuff:
http://thesamba.com/vw/classifieds/inde ... 1245344572
Ryan
[This message has been edited by 72 Beetle (edited 11-20-2002).]
Ryan
- Plasticfantastic
Yeah, I saw that too...
I'm not sure I understand the mechanics of how the narrowed beam fits though. I guess you narrow it to bolt to the inside of the frame instead of the outside ... but you're still limited by the frame itself as to how far you can tuck a wide tire it seems ... being a novice on this kinda stuff sure sucks sometimes
thats what happens when your trying to be a nice guy a teach a friend how to do something. then he turns around and undercuts your product price since he is a new "master at doing these"
not very cool. not interested in doing business with people like that. also his are not gusset welded like mine and wolfgang(which i think is nessecary)
- Plasticfantastic
Jeeze .... I thought only I had "friends" like that ....
For those that are interested, hopefully I'll be able to give a full review of rizz's spindles in a couple of weeks along with how hard they are to install when you've NEVER done it before. Trying to beg the money out of the "boss" now, shooting for the end of the month.
