Project CFC#1, turbo, back halfed and light (new name, new car page 15)
panel
Re: Yes, I'm building..., **EDIT** Bought a 2165cc :) Official 10sec car!! Now project 9sec...
Post by panel »
bug66 wrote: Fri Jan 19, 2018 5:48 pm Ah, on the back (towards the front of the car, it will be flats, and the fronts will be trimmed for airflow and engine lid closing
I'd go with rounded end caps. Most pressure vessels have rounded end caps like Propane tanks etc. I'm pretty sure Marty Staggs did some research on that and you'll see most intakes even the inline 4's will NOT have flat end caps.
https://www.thesamba.com/vw/classifieds ... id=1932365
http://notchdrag.blogspot.ca/2011/12/
bug66
Post by bug66 »
What was the reason or improvements on round caps? Towards the lid there is just no room..
Can’t find 4’’ caps in 3mm either..
Boost was created only to make people smile, and make power! 8)
10.626 @ 132mph SCC2016
10.407 @ 134mph SCC2017
10.221 @ 135mph SCC2018
Clonebug
Post by Clonebug »
Round caps won't flex with pressure whereas flat ends will tend to bulge a bit when pressurized.
Chip Birks
Post by Chip Birks »
Better keep that boost below 1500psi then!
Clonebug
Post by Clonebug »
Chip Birks wrote: Sun Jan 28, 2018 8:24 am Better keep that boost below 1500psi then!
At 25 lbs. there probably won't be and issue unless he uses paper thin plate........ :wink:
Chip Birks
Sounds like he's using .120 thick stuff. He'll be fine as high as he want to go.
bug66
Post by bug66 »
Everything is 3mm/.120’’ except the trumpets. They are 2mm.
The tube from turbo to IC is 1,6 my steel.
Won’t burst :)
bug66
Post by bug66 »
It's been a while :D
A lot have hapened.
New heads (old ones leaked on the outside of the valve seat) and new ones are cheaper than fixing.. They also where a set with longer valves, and V8 springs. Not the easiest on 044 style heads.
New heads are still 044 Wedgeport 44/37,5 but the new style. Looks good with the new combution chamber.
I also made sure the front gearbox mount won't bend again..
V-bands welded between intake and IC
And how it looks with almost all the bells and whistles
bug66
Post by bug66 »
In other news,
The new gearbox is complete, in Norway, axles etc. fitted and mounted in the car :twisted:
I've also bought a new 50mm Tial blow off valve, and new 215/65-15 MH DOT slicks. If they could brake the last gearbox in half, they should be able to get me in the 9's...
rubenski
Post by rubenski »
Wow. You've got some nice stuff!
Engine bay is pretty crowded!
bug66
Post by bug66 »
rubenski wrote: Tue Jun 12, 2018 6:15 am Wow. You've got some nice stuff!
Intercooler is well into the car 😂
Chip Birks
Did you end up with some 2000cc injectors?
madmike
Post by madmike »
Any reason your not eliminating the nose cone mount? and just run a midmount ?
petew
Post by petew »
madmike wrote: Tue Jun 12, 2018 3:39 pm Any reason your not eliminating the nose cone mount? and just run a midmount ?
Or run both. Seems like it could do with all the help it can get. :shock:
bug66
Post by bug66 »
Chip Birks wrote: Tue Jun 12, 2018 11:13 am Did you end up with some 2000cc injectors?
Yup. 2200cc Bosch
