Drag and Drive Baja
- Schweg
Re: Turbo/EFI Baja
Thanks Clone!
I appreciate the information. I’m gonna work on mine this week.
- buguy
Re: Turbo/EFI Baja
I'm actually back to normal now. My waste gate line had a hole burned into it so it was all goofy!
Once that was fixed I started at 10 up to 80% and 4000 rpms. That sucked and was really strange feeling. So I just changed all the 10 fields to 50. Boost cut set on 300 kpa and it's banging it pretty easy so I'm going to try backing it down. Or maybe I should increase the boost cut! Ha! No!
Isn't the number you enter into the field a percentage of how much it bleeds off? Like I'm on 50 so it bleeds off 50% of the air moving through it. In a pulse width manner?
- Schweg
Re: Turbo/EFI Baja
So what I interpreted the manual to say is the number your putting in is duty cycle. IE the percent of time it’s closed ( normal ) or open ( inverted ).buguy wrote:I'm actually back to normal now. My waste gate line had a hole burned into it so it was all goofy!
Also found a quote in the MS3 manual that says max boost is utilized in a very harsh manor as it’s designed to save an engine. Where as we use it similar to a rev limiter. Explains why it’s so violent.
- buguy
Re: Turbo/EFI Baja
I hadn't intended to use it as a rev limiter.... But I couldn't get the boost down, so I was glad it was there. I have a feeling I'm going to end up around the 30 mark for duty cycle to keep it off the cut.
- Schweg
Re: Turbo/EFI Baja
As some cooler weather creeps in to the east coast I can’t help but notice that My AFRs are off from what they are tune to. Did I miss a setting in TS?
I was reading last night about AFR target and EGO. EGO seemed right but I’m not sure any clarification would be great.
Schweg
Schweg
- buguy
Re: Turbo/EFI Baja
Good question. I've been wondering what is going to happen with mine as it cools down. Kind of excited to see how it reacts to cooler IAT's.
- Schweg
Re: Turbo/EFI Baja
So I’m not sure mine is adjusting to air temps. I’m just showing leaner AFR which is making me think I’m missing something setting wise.
- panel
Re: Turbo/EFI Baja
Wonder if there is a MAT correction kinda like they use for heat soak. But maybe yours is the other way and the IAT sensor is getting cooler ?
- buguy
Re: Turbo/EFI Baja
Would that only be if you were map based tuning?
- Chip Birks
- buguy
Re: Turbo/EFI Baja
No I meant MAP. Wouldn't it change with weather like it does in elevation?
- Chip Birks
Re: Turbo/EFI Baja
Ah I see. I don't know that i have seen a ton of change, but I suppose it's probably reality.
- Schweg
Re: Turbo/EFI Baja
I’m in MAP based currently so I’m not sure if I need ego on for it to work
- buguy
Re: Turbo/EFI Baja
I am TPS based with EGO on
- buguy
Re: Turbo/EFI Baja
Hey dude how big is your throttle body? The ID
