I've got a LOT of catching up to do now that STF is finally back up and running. A lot had happened since my last post, and not as much of it was as good as I would have hoped. In summary, those chinese clone IDFs were total crap. They may be useful as a set of ITB's if I ever go with a home brew EFI setup, but that's about all I'd trust them to do. Rather than rewrite everything I'll just cut and paste the posts from over on TOS.
After getting back from a little road trip down to CO I had the first carb waiting for me when I got home. I spent a little time taking the IDF clone apart and giving it a brief preliminary inspection.
There are a few obvious things I have already found so far:
1) There are brass and aluminum metal flakes all throughout the carb. Even between the gasket and the top casting. A thorough cleaning should be considered MANDATORY with these carbs, not just a "good idea".
2) The carb came soaked with an oily substance, which is most likely supposed to be a metal preservative to prevent corrosion during shipping and storage before being sold. The stuff smells a lot like either lamp oil or kerosene. There was quite a bit of the fluid inside the carb body and the orifices when I was disassembling the carb.
3) The top casting has rough surfaces on the inside of the bores just above the gasket between it and the body. This is a little too rough to leave it as received. I'll smooth it over and polish up the bores to fix it before I reassemble the carb.
4) The cold idle enrichment circuit holes are empty and unused under the side cover plate. Given the area I live at, and the temperatures we see here regularly, I was hoping the enrichment circuits would have been intact and functional. If it looks like I absolutely need them later, I'll have to find all those pieces and fit them to the carb.
5) The gasket between the top plate and the carb body was torn near one of the bolt holes. It didn't stick to the carb body or the top plate and I didn't tear it on disassembly, so it had to have been torn during assembly at the factory. Where the tear is I could probably just reuse the gasket. However with all the brass specks embedded in it and the tear on the corner, I'll just go ahead and replace it before I put it back together.
6) Casting flashing was all over the pieces above the venturies in the bores. I'll clean these up, but I was a little surprised at how much there was on these parts.
7) The venturies don't have hardly any casting flash like on the other parts, but they have some squared off shoulder edges in the bores. These should probably be blended in better, but I may run them as is to see how they work like that. The shoulders aren't protruding into the airflow as it moves down through it. Rather the steps are sharply cut back from the surface above it.
8 ) A lot of the other places where the castings form an opening for the bores have rough edges and some casting flash visible. These will all be worked over to remove all flash and then smooth and radius the sharp edges as needed to create a smooth flowing bore for the air to pass through. Leaving these edges in as received condition isn't an option IMHO.
All these little issues, and any others I find when I look deeper into it, are just confirming the need to give these carbs a thorough tear down and inspection when you get them. So far I haven't found anything that can't be easily fixed, aside from the missing enrichment circuit parts, with just a little elbow grease and a few simple tools. If you can bolt these carbs onto an engine, you probably already have everything you need.
Now, onto the pics!
Here's a look at the steps on the insides of the venturies and some of the casting flash on the pieces above them.
Bent arm from rough handling in shipping maybe? The packaging could have been a bit better IMHO.
The "40" laser printed on the flange is the only marking of any kind anywhere on the carb. The jets are marked with their sizes, but they don't help ID the carb itself in any meaningful way.
Float looks way off in this pic. Will check and adjust before reassembly.
Corner of the gasket was torn near a bolt hole by the factory during assembly.
Specs of brass dust/shavings embedded into the gasket. These metallic particles have also been found in the float bowl and interior spaces of the carb.
I hope the pics and info posted here will be of use to any other people considering buying these chinese IDF copies. I pretty much had to just go on faith that they would be decent enough to use since I couldn't find any current info on these anywhere before buying them. There's plenty of info to be found on the real Weber IDFs and EMPI HPMXs. Let me know if anyone needs more detailed info or pics of any particular areas and I'll do my best to help.
