1967 912 Type 4 Turbo Build
Cameron Henlin
Re: 1967 912 Type 4 Turbo Build
Post by Cameron Henlin »
panel wrote: Fri Dec 15, 2023 8:44 pm I'm wondering if it'd be easier to swap one of the turbos around so the plumbing of the exhausts or intake(air cleaners) would be better/cleaner and simpler If the exhausts were inside you could link them together ?
I really like the way that looks but I’m not a great welder. This is easier for me to setup and do a downpipe setup off of. I have some 2” piping on the way and just need to make to S shaped downpipes to put things around the original exhaust exit on the 912 body, which I am trying to avoid modifying. Something like what I drew on the attached picture in red
panel
Post by panel »
Just try to keep the passengers side exhaust heat from the drivers side cold air intake.
Cameron Henlin
panel wrote: Sat Dec 16, 2023 11:25 am Just try to keep the passengers side exhaust heat from the drivers side cold air intake.
Yeah I plan on wrapping the downpipes with quality lava wrap to keep the temps down. Luckily running on megasquirt I have constant air intake temperature monitoring so I have an easy way to keep an eye on things
