Zane Hall wrote:
This '73 probably won't be my last VW.
If you get that one it probably will be. By the time you realize that it's going to cost more than you have or can make in a couple years to make roadworthy, you'll be so discusted w/ VWs, broke and so pissed-off that H*ndas will start looking go to you.
Once you start plunkin' down your hard earned $$$ for that motor, you will find out just how much it will cost. From my shop, the last 4-5 STOCK type-4 motor re-builds have cost in the neighborhood of $3500-$4500 depending on the condition of the heads. . . Oh thats right you don't have a core with good heads. . . You don't have tins. . . You don't have a case with all your core parts (crank, rods cam lifters) etc, etc, etc. . .
When do you expect to get all this work done??? Between the full time job it's going to take to earn all the money it's going to take and school(??), a girlfriend maybe (those can cost you a ton of $$$ too
), just when do you plan to perform this miraculous reserection of your parts bus???
We all know that you WANT to do this; no question about that. Your enthusiasm is commendable, noble and just darned infectious. However, you have asked a lot of people with a heck of a lot more experience, knowlege (and probably $$$, but I don't know your finances) what we thought of that bus?? The overwhelming response has been to look for another candidate for your efforts. If I were you, I WOULD HEED THAT ADVICE!!
In case you are still reading and considering your "diamond", here's a few things to consider about that bus that may have escaped you in your moments of joyful pre-purchase state of mind:
1. Plan on replacing ALL brake hydraulic components. Sitting that long they will be toast (expect around $450 minimum, if you need shoes, pads rotors and drums add another $250+)
2. Plan on pulling the tank and POR-15 treatment ($75 or so)
3. That trans if it needs replacing will set you back around $800 with shipping
4. I've already talked about the motor ($4500 for arguments sake)
5. Tires X 4 (around $400 out the door)
6. Recovering front seats (who cares about the passangers right?) (around $300 for a TMI kit and new pads)
7. A new clutch kit since that was attached to the MIA engine ($200)
8. Getting the electrical system squared away (hard to say. Could be easy if you're familiar with them, but if your not. . . You may have to take it to a professional BIG $$$ there)
9. You can add another $400-500 for incidental things that ALWAYS some up like a rear mount bar , engine/trans mounts fuel hose, etc, etc, etc.
10. Carbs for the MIA motor ($450-$850 depending on what you get)
11. Count on new shocks and steering stabilizer (around $140)
12. Tail lights, blinkers and headlights ($150)
13. Rear bumper ($100) Oh never mind, it actually HAS that
TOTAL:
$7715.00 (and I know a lot of other stuff will be needed to just get it on the road; there always is). Also this is if YOU do ALL the repairs yourself. You could easily hit the $10K mark if a shop did them. . .
Conversely, you could purchase this bus and have it shipped to your door for half that and have 10X the bus.
http://www.thesamba.com/vw/classifieds/ ... ?id=520823
That doesn't even address the rust, body & paint and everything that comes with doing that type of stuff. . . Anyone who has done a full restoration will tell you that the single biggest expense is the rust repair, body work and paint work. Even at Macco with all the rust repair already done, I woulld expect a quote around $2500-$4000. . .
Again, as I stated before, I DO THIS FOR A LIVING. I DO HIGH-DOLLAR RESTORATIONS ON CARS WORTH $15K LESS (sometimes more) THAN THEY COST TO DO WHEN DONE. THAT'S JUST THE NATURE OF DOING A RESTORATION. AT BEST, USE THIS AS A PARTS BUS FOR ANOTHER DRIVER THAT YOU BUY AND DRIVE DAILY.
(soap box off) But hey, if you want my opinnion, I say go for it dude!! Looks like a sweet, pimpin' bus. . .
Whew, I need a beer. . .
