Drag and Drive Baja
Schweg
Re: Turbo/EFI Baja
Post by Schweg »
Got the stereo moved and switches allowing me to fab up a screen mount that won’t take me knee cap off and allows me to see it well.
Down fall is that I programmed Tunerstudio to start automatically and I can’t seem to get to the desktop to load my project and dash board I built.
I have some time hope to get the Td04-9b on tonight and maybe some 880cc injectors and flex fuel this weekend. We will see.
buguy
Re: Turbo/EFI Baja
Post by buguy »
Those are big injectors! I have 850's and the most i think i ever saw was 65% duty cycle. That was on 30 psi of boost and E85. I don't remember where they were with the new engine.
Chip Birks
Re: Turbo/EFI Baja
Post by Chip Birks »
Dash looks good! Gonna be compounding by next week?
Schweg
Turbo/EFI Baja
Post by Schweg »
Chip Birks wrote:Dash looks good! Gonna be compounding by next week?
Thanks!
Um.... doubtful. I need to get my rear cage modified and back on to hang the holset. I need to weld up all the exhaust and intake plumbing between the two. And buy silicone adapters for all that as well.
Unless I just use the 9b and 13t compound combo then it’s a lot less BS. Now I need to do some research.
Oh and Buguy I was wrong they are 850cc. I hope to see 35-40 psi with the compound set up.
Chip Birks
Re: Turbo/EFI Baja
Schweg wrote: Fri Nov 20, 2020 2:27 pm
Thanks!
I thought that maybe that was your plan for the immediate future. Might not be enough difference between the two to really benefit though.
Schweg
Re: Turbo/EFI Baja
Post by Schweg »
I bounce back and forth on what the plan is. Good thing I’m in charge.
buguy
Re: Turbo/EFI Baja
Post by buguy »
What rpm are you getting boost with the 13t?
And aren't you running stock rods?!
Schweg
Turbo/EFI Baja
Post by Schweg »
buguy wrote:What rpm are you getting boost with the 13t?
I start building around 2200-2300 but it’s always building I never hit a boost level.
And yes stock everything.
buguy
Re: Turbo/EFI Baja
Post by buguy »
That's how mine was too. It seemed that i would run out of rpm before it stopped making boost. Most i think i ever saw was just over 31 psi.
If you hit 40 psi on stock stuff you will be my new hero!
Schweg
Re: Turbo/EFI Baja
Post by Schweg »
buguy wrote:That's how mine was too. It seemed that i would run out of rpm before it stopped making boost. Most i think i ever saw was just over 31 psi.
The compound set up will push a ton! 40 is the low end for what I’m building. To keep things at peak efficiency I need like 48-50.
But I’m hoping to be up and running with it and e85 in a few weeks. But probably first of the year.
buguy
Re: Turbo/EFI Baja
Post by buguy »
Are you going to put a ratchet strap around it to keep the heads from pushing off?!
Schweg
Re: Turbo/EFI Baja
Post by Schweg »
buguy wrote:Are you going to put a ratchet strap around it to keep the heads from pushing off?!
I’m thinking I’ll just tack them onto the cylinders or JB weld.
Honestly I plan to add good studs to it so the heads stay on.... for a bit.
buguy
Re: Turbo/EFI Baja
Post by buguy »
I love it. Can't wait to see it in action!
rubenski
Re: Turbo/EFI Baja
Post by rubenski »
Schweg wrote:I bounce back and forth on what the plan is. Good thing I’m in charge.
Well said!
buguy
Re: Turbo/EFI Baja
Post by buguy »
How do you charge the tablet?
