DEUTZ 912 CYLINDERS
- dstar5000
Re: DEUTZ 912 CYLINDERS
YEP! I cut them 1/4" longer than needed to begin with.....
DOn
DOn
"Let me say it as simply as I can: transparency and the rule of law will be the touchstones
of this presidency,".. Barack Obama January 21, 2009, 30 minutes before he signed the law
sealing all his personal information....
I was thinking of that cam for my 78x103 naturally aspirated mild street engine. I have tried two different 86Bs (108 and 114 LC) in 2.3 liter T1 engines. I now run a custom 115LC 86A and I love it. After over-camming many different builds I'm getting smarter about it...dstar5000 wrote:86b/86b+? on 114LCs has been ordered!
Don
Steve
My Baja Build
My Baja Build
- dstar5000
SInce it was turbo'd, I wanted to keep the lift to .500 and up the duration.
Easier on the springs.....
Don
Don
The 86B setups I ran lifted to 0.583" with Scat 1.4 (1.53 actual with this setup) geometry. Now with the same rockers but 86A I'm lifting 0.520. Much happier. I removed some shims and dropped from 355 to 325 punds over the nose pressure (4047 bugpack springs).
Steve
My Baja Build
My Baja Build
- dstar5000
I'm running the 1.3s and the Crower springs are 350 @ nose, at .500".
Don
Don
Awesome Project Don! I have Deutz cylinders aswell and had to do the same mods basically.Additionally I had to machine the grooves where the headstuds go through because the cylinder spacing is to wide,even with the time-cert bushings for the 8mm Raceware headstuds.I have a different series cylinder though.Mine has a 102mm bore stock.I have the CP pistons on order then the engine will be finished! Are you back in the States now or still in Rammstein?
Mark
Mark
- dstar5000
I'm back in the States now! Ordered some CP Pistons as well....104mm.
Got a set of Len's LE-200 heads too!
And twin t28 turbos....
Don
Don
Damn...it´s too bad we never had the chance to meet while you were here! But I´m sure you´re glad to be back home! I have the chance coming up to work in Mobile, Alabama...but I hate skeeters and I hate snakes!
Beautiful area though! Who knows the company might send me anyway to train people there.
Twin t28´s? Nice! Why did you decide to go twin turbo? Will you be running efi? Which ECU?
- dstar5000
YEP! Twin BB turbos spool faster....
Polished the case and now working on polishing the plenum for a nice look!
Don
Don
- CobraJet
Where would one find a place that does this? Did you do the case polishing yourself or?
- dstar5000
Sears' polishing kit comes with three different polishing sticks and bonnets....
Expect to spend a whole day just deburring the case before spending a hard 24-30 man-hours
polishing the case.
It would cost $200-$300 to get one polished....
I just spent 3 hrs grinding the welds on the plenum and am only half done!
Don
Don
polishing the case.
Don
Don
- CobraJet
Been there done that, don't like the mess it involves. Even though I used a good mask it felt like I had boogers in my nose for a week after polishing all the aluminum on my old Harley.
Just a small part ....
Nice work Don! I don´t have the patience for stuff like that! My hat´s off to you! That´s going to be one hell of an engine! Which tranny are you going to mate it to?
- dstar5000
Mendeola 5 speed.....Theoretical top speed is 164mph....doubt it gets there in a 21 window Splitty!
DOn
DOn
Nice!!!!! With the right suspension it would be possible.There's a race taxi T1 with a 500hp twin turbo Porsche engine/G50 trans at Spa that does those speeds.It's been widened and heavily modified but no spoilers..
http://www.race-taxi.ch/indexx.htm
