My Megasquirt build, Volksbugly
- Chip Birks
Re: My Megasquirt build, Volksbugly
Why is your MAT so hot? What turbo do you have? Where is your sensor located? Is it an open element type? Is it a gm one?
- volksbugly
Its a bad configuration. The shop that did the work didn't put in the tin to block the exhaust heat, So all that heat gets into the engine bay. Its on my to do list to remedy it.
for reference 2am in the morning on the interstate, when its cold out, its incredibly fast. (super-car territory) My back is finally in a place where I can wrench again. But now its so freakin cold out... and of course its pouring down rain.... Arrrghhh! I just want to Feel boost again! I mean I just want to drive my car without it bucking.
- volksbugly
Wow I haven't updated this in a long time! So the bucking problem was resolved. the TPS wires were run directly in front of my fan and got eaten up... so that was resolved and then I was having a hard time making boost... that was resolved it was due to much heat... resolved it with methanol injection... so now I can make good boost, have launch control working with a button, not a clutch switch so no "flat shift" at the moment, but now I have a pretty bad oil leak... fixed one leak it was the valve cover, but now I cant tell where the other leak is. The oil leak is bad enough that it smokes pretty bad that I cannot drive it on the road. I have to get it on a rack somewhere to take a good look. It might be the turbo. It only leaks/smokes when I get it into high rpm. After I get that resolved its back to the exhaust shop to have one EGT bung removed and rewelded Its pointed right at my mendeola stiffy bar, ooops! When thats done then I can get my EGTs monitored, then install my Flexfuel, replace my aluminium lines with some SS lines, get that E85 tuneed in, then run true flex! and make some real boost safely!
I suspect I'm breaking into the 12 second mark now. Expecially if I put on slicks. If I am on some nice road now I can almost pull the front with my crappy 280 compound tires! lol dialing in launch really is pretty awesome! ok ok enough exclamation points
on a different note: I got my front chin spoiler in from CreativeCarCraft: http://www.creativecarcraft.com/
Project Rocket Bug is in the works. I plan to also put on a wing and then finally build a rear diffuser that will also second as an oil catch tray. Then I'm done with Aero for a while!
sounds great!
- volksbugly
I never did mention this or maybe I did. but that day that I was doing the dyno pull it was 100+ out at Racewarz in Sacramento 2016Chip Birks wrote: ↑Tue Jan 10, 2017 3:41 pm Why is your MAT so hot? What turbo do you have? Where is your sensor located? Is it an open element type? Is it a gm one?
- volksbugly
Enjoy some photos:
Over all Album
https://goo.gl/photos/mx1BhZShBxAWWXCb9
Dyno run 2016 100+ degrees that day (click the video when it starts to play for full screen)
https://photos.app.goo.gl/WKRpJgJSCP8HfVZH8
Pan-Evac setup
https://photos.app.goo.gl/Cqu8rRWzXiZabgKk6
https://photos.app.goo.gl/PVdAbQbCuq23GS9W7
Water Methanol Injection
https://photos.app.goo.gl/8EqsXByftYjcNWLg7
Havent put these on yet, going to replace the CB Breather and mount this.
https://photos.app.goo.gl/gLC3fFurfKdKJFJx7
https://photos.app.goo.gl/pJKbajpBwMSeesSd9
https://photos.app.goo.gl/E8dy9ej7c61gBSqy5
https://photos.app.goo.gl/SN2cKLt4UsxjVD8YA
https://photos.app.goo.gl/HKoLqRXi464teUP58
https://photos.app.goo.gl/CGis35CPkaVsXdG49
Over all Album
Pan-Evac setup
- Chip Birks
Hottest mine has ever been was 220 or so going into my intercooler. That was with my wastegate essentially closed while targeting a huge amount of boost but only making 13psi because of a massive intake leak. My turbo was working super hard, but couldn't make it happen, thus the heat.volksbugly wrote: ↑Fri Dec 14, 2018 3:20 pmI never did mention this or maybe I did. but that day that I was doing the dyno pull it was 100+ out at Racewarz in Sacramento 2016Chip Birks wrote: ↑Tue Jan 10, 2017 3:41 pm Why is your MAT so hot? What turbo do you have? Where is your sensor located? Is it an open element type? Is it a gm one?
- volksbugly
Oh wow, I really suck at updating things. With a little one running around now everything takes well, an undetermined amount of time.
ok if I remember the measurements correctly I was at around 280 IAT that is measuring it at the bell mouth. so yeah its, open element GM style It was heat soaked from running at the track all day and hardly any shade. the ecu was being safe and retarded the timing to -17 yeah thats right negative 17 ... lol I was like ok cool and what a trip... Really makes me want to get my EGTs finished up. Oh I also burned my hand when trying to open the decklid that was so nice to go along with my sunburn... Hella fun day!
- volksbugly
Finally back into a shop! Sharing a warehouse space with 3 others I'm pulling the motor and trying to figure out the leak, putting in a 5 speed, putting in the Porsche 944 rear suspension, finally getting some meat under it, making a removable rear clip, then once thats all done and rolling, get a rollcage put in. or maybe do one myself.
