throttle linkage
- sgeorgejr
throttle linkage
After looking at several pictures and posts, it looks like people set up the throttle linkages 2 different ways on these cars (either toward the front, or the rear of the engine). Is their a prefered way to set these up?
- Rouser914S
No, but you can modify the carb linkage to work great with the stock cable prretty easily.sgeorgejr wrote:Is there a part that i can buy to convert my existing cable to work with this carb linkage?
I'm sorry I didn't take pics before I ditched the H-bar--- I eventually made my own linkage from 2 small pulleys, a motorcycle cable splitter, and 2 bicycle brake cables, a couple of bits of angle iron.
Worked MUCH better than a Hexbar.
Only ever had to adjust it once, and my accellerator pumps stopped piddling continuously.
Then I ditched the carbs entirely for the L-Jet manifolds and CIS.
I should have done it sooner.
That setup will work pretty well with the stock cable, I hear
I miss the music of the Webers, but that's all I miss.
This is off topic...but I wanted to spark a thought in piledrivers head. Think of this (you probably already have)......the CIS fuel distributor unit and the control pressure regulator...simply as a very nice fuel pressure regulator.........feeding electronic injectors........that only see triggering impulse attached to the ignition either at the distibutor or a crank trigger wheel. That way they are rpm sensitive. As airflow rises....fuel pressure rises but more more precisley than a vacuum regulator could do it. Then you set the pulse rate to decrease as rpm rises to keep it in check.....
Just having fun! Ray
