I HOPE SOMEONE CAN HELP ME IM TRYING TO FIND
WHAT THE MEASURMENT IS FROM THE DISK SURFACE OF
THE FLYWHEEL TO THE PLATE SURFACE I MEARSURED
.890 ON MY 914-4 FLYWHEEL I CHECKED MY MANUALS IT
DOESNT LIST THIS DIMENSION IF THIS IS TO MUCH CAN
THE STEP THAT THE PRESSURE PLATE SEATS ON BE MACHINED
DOWN IF SO HOW MUCH
THANKS BILL
FLYWHEEL STEP RESURFACE
- Bills914-4
Bill DeWitt
2800cc 914-4
TwinPlugs & MegaSquirted
Now Boosted 7-10 psi
Weekend Therapy
2800cc 914-4
Weekend Therapy
Re: FLYWHEEL STEP RESURFACE
IIRC, ~0.890" is what all the 914/Bus flywheels I checked out the other day measured... (one is essentially new refurb)WLD914 wrote:I HOPE SOMEONE CAN HELP ME IM TRYING TO FIND
DOWN IF SO HOW MUCH
THANKS BILL
...and yes, they can be remachined. Both surfaces get the same cut.
Make sure you go somewhere that does it all the time.
OTOH, mine work fine at .890, so if you are having a clutch problem, that probably ISN'T it.
The FW doesn't wear all that much, but it might not be FLAT anymore, or it could be many other things.
You might want to describe the exact problem you are having here, preferably not in all caps, it's very hard to read, and is actually HOW YOU YELL on the net.
- Bills914-4
Thanks for the reply
Sorry about YELLING didnt know
Im new to PC key board stuff At work I type on
the CNC machines (PROGRAMS) its all Caps
Yeah I talked to Jorge at EMW he told me its 22.5mm
which works out to about .886in. The reason the first
post is my clutch is slipping in the power band its a 215mm
4 puck sprungcenter (clutch.net) at 2500-3000 if I sidestep or
Nail it to the floor it slips a little (HD 2.0 sachs plate)
I guess its time for a aftermarket pressure plate
which means balancing also I did cut the step down(.030)
it seemed to help some a little more pressure but not enough
Thanks Again
Bill
Thanks Again
Bill
Bill DeWitt
2800cc 914-4
Weekend Therapy
2800cc 914-4
Weekend Therapy
With a 2.8 in a 914, you might consider a HD plate an investment
Sounds like fun!!!
Just a thought---
I've been running a 228 Vanagon plate for years...In my 914. Yes. the starter engages fine.
Vanagon flywheels are forged, and just need the center of the FW reamed and the input shaft bearing pressed in.
MUCH more holding power with a 9" clutch, and if all else fails, Kennedy uses those on V8s...sells 228 plates good for stupid power that require a hydraulic setup to operate.
Sounds like fun!!!
Just a thought---
- Bleyseng
What ever you machine off you must space the little ball amr below the clutch arm. Install a spacer under it and use a thread sealant on the threads when reinstalling. It leaks otherwise.
Use the 911 clutch disc too with the six springs.
Make sure the disc isn't hitting the flywheel bolts if you cut alot off! Alot of times this is the case why the PP isn't holding the disc as well.
