Jadewombat wrote:Where did you get your lower tins and alt. stand? Looks pretty good, I'm not into carbs though. Quite a crank pulley on there, too.
The lower tin had to be made up, unfortunatly i dont have any pics of these off the engine but i just got a flat piece of plate bolted to the bosses behind the pulley (fan housing mount i think)and with the trimmed up large rear tin attached i drew the radius on the flat plate.I then cut it allowing enough to bend over a flange so it tucks under the rear bit.Lower deflector plates are just 21swg tin bent to the same shape as the type 1 equivilent part and thats basically all i did for the whole conversion .I just looked at the type 1 and put tinware in a relative position.
See also my post in the "why choose a tpye 4 ".
The pulley i made myself (i used to be a production engineer).Its way over the top ,made from stainless steel as i was going to lighten the flywheel and thought this would stop any crank flexing at high rpm .I will probably make an ally one as i never got round to lightning the flywheel.
Pedastool is a cut off type 1 part bolted to a milled ally plate that fits into the breather tower.I have remade this part since these pics to remove that spacer.
I made all the tin for this in around 1994 but got it in the car just two years ago .Since the internet revoloution i have found plenty of people who have done similar conversions but here is a link to the best site i have seen regarding this type of conversion which has been badged the Cali Conversion in America.
http://www.aircooledtech.com/type4_upright_conversion/
