Oil Pressure.
jblazin82
Oil Pressure.
Post by jblazin82 »
What is normal pressure for a 2056cc engine anyone? Jake?
Rouser914S
Post by Rouser914S »
Let's move this over to "The Type 4rum" for a few more hits.
Hot idle ~15 PSI or higher is typical, even stock.
I wouldn'd sweat it much if above ~10 PSI though, as long as it all sounds OK.
Check it with a mechanical gauge. The VDOs are known for reading low..
~30-40 running down the road, hot.
What oil are you running, cooling system etc..?
jblazin82
Post by jblazin82 »
I have a brand new 2056 t4 with a cooler on the roof. started engine the other day and had 20-25 at idle.
Unkl Ian
Post by Unkl Ian »
What are you running for oil ?
jblazin82
Post by jblazin82 »
Im running castrol hd 30w.
