Worn Push Rods?
- Widetrack
Worn Push Rods?
I have taken apart a 2L Type 4 that would not completely rotate and the only thing I found damaged was a badly worn pushrod about two inches from the end. One of the lifters cannot be pullled out with the end of a finger. With one head off the motor again rotated 360. Heads look fine. Rockers look good. Some of the other push rods are marked from dented pushrod tubes but could the badly worn one stop the rotation? thanks DG
- Rouser914S
Possibly ate the lifter, motor/oil pump full of iron shards at best.
Might be able to tell more pulling the jugs and maybe rods to get a look at the lifter from the other side.
- Dave_Darling
- david58
Well it is very understandable why you would think that way. Pay attention.Rouser914S wrote:Honestly, I can't see why it would stop the engine from rotating, since it doesn't come into contact with the pushrod,
You have something else going on internally.
