Hello im new!!
madsupra88
Hello im new!!
Post by madsupra88 »
Sup guys, im new to the forums, i just picked up a 1972 porsche 914 1.7L
Hoping to get know you guys, and share some information.
i have never owned a porsche and i have never worked one either, im mainly into my current project (88 turbo Supra)..
anyways here is some pics of the car
thanks
-saif
bulli74
Welcome!
Post by bulli74 »
Welcome Saif,
Welcome to Shop Talk Forums! your 914 looks good is it running? looks like you just need some tires and some grille deletes for the bumper. anyways good luck and dont hesitate to ask any questions..
Chris
1972 Porsche 914
1967 Honda S65
1970 Yamaha R5
1997 VW Jetta Trek
madsupra88
Yes it runs, but the fuel pump is giving out on it, they sort of hard to find, is there any other fuel pump i can use as long as it goves out same pressure??
-saif
madsupra88
Thanks for the link. now is there any suggestions on what other fuel pump i can use other than porsche?
Dave_Darling
Post by Dave_Darling »
Does it have stock fuel injection, or has someone converted it to carbs?
Most modern EFI fuel pumps, as far as I can tell, put out enough pressure and volume for the stock D-jetronic EFI. There are cheap Facet "clacker" pumps for carbs, or more expensive rotary ones. The rotaries are preferred for less noise and generally higher reliability, but the Facet pumps are cheap....
The "EP7262" in the link above looks to be the stock 70-74 914 fuel pump.
Pelican also carries the stock pumps. Note that using the 75-76 pump, while cheaper, requires a moderate amount of re-plumbing.
--DD
