Removing fuel line from tunnel?
Jimbo70
Post by Jimbo70 »
(I'm also posting this in Speed and Drag Racing section)
What holds the hard line in the tunnel? I want to remove the stock F.I. feed line and replace it with 3/8" line. I have the rubber escutcheons removed from either end, and I can turn it with some difficulty. Is there some hidden fastener I need to remove to get the line out?
Thanks,
Jim
Tom Notch
Post by Tom Notch »
There are several metal clips that the fuel line is held in by. Fuel line is inserted under them and then the clip is bent down over it. You won't be able to replace the steel line with anything without opening up the tunnel as all the bits are fastened in before the bottom is welded on.
Tom
Tom's Old VW Home
DVKK
DSD, dark side disciples
Jimbo70
Post by Jimbo70 »
I guess I'll just have to deal with the line I have in there then.
Thanks,
Jim
I believe that the exact locations of where to cut...bend back the metal...and lift the clips is in a lot of locations in the shop talk forums. That being said....if you do not want to do all the cutting....what changed that makes you think you need a larger line? Ray
doc
Site Admin
Post by doc »
STF member Caslor has some excellent tunnel repair pictures in some of his initial posts. Search for Caslor's posts. The pics may offer significant guidance.
Good luck,
doc
mrweasel wrote:
mrweasel
rusty model a wrote:This is the solution I came up with to fix my broken middle mount. I do not know how to weld yet. I formed this bracket to place the broken bracket back in its original location. I formed the bottom to wrap around the clutch cable tube but made sure it ended prior to the fuel line. Hopefully this will work good. Image
Dolamite02 wrote:Are you looking for something like these?
Bugs'n'Pugs wrote:Image
mackaymanx
Post by mackaymanx »
Tom Notch
Post by Tom Notch »
While those are great pix of a t1 tunnel, a T3 is different. The fuel lines are attached to the sides of the tunnel. This means you have to try a different tactic on cutting holes into it.
ask me how I know....... :oops:
Tom
Tom's Old VW Home
DVKK
You didn't take pics? :cry:
Tom Notch wrote:While those are great pix of a t1 tunnel, a T3 is different. The fuel lines are attached to the sides of the tunnel. This means you have to try a different tactic on cutting holes into it.
Ok should I remove these pics from the type 3 thread and start a new thread? I thought they would be the same thanks for pointing out the differences Tom.
Those are great pics! Have them stickied to the type 1 forum. Ray
