I am starting some work on my 60 SC. For the front backing plates do they pass over the inner bearing race or is there something I have to do to get them past? It doesn't look like the ID of the backing plate is larger then the OD of the race? Secondly how is the rear emergency cable held in place by the backing plate (need to take out to remove the plate)? thanks for any help.
emergency cable figured out. Bentley manual doesn't say anything about a retaining hardware to remove. Hard to see when you are digging through 20 years of dirt and grime. Now just the front backing plate to go.
