stock type 4 cooling in split
59panelvan
Post by 59panelvan »
hi anybody running the stock type 4 cooling in there split? i,ve got a 2.4 type 4 motor, megasquirt efi and a t28 turbo in my 59 bus and was wondering if anybody has encountered cooling problems? i,m also running a mocal cooler and fan underneath, mine will be on the road in about a week so as yet i,m not sure if its going to be ok, but have been looking on some forums and people have had trouble.....anbody???
MNAirHead
Post by MNAirHead »
Please confirm fan underneath.. do you mean a fan pushing air back upward into the engine bay from the underside?
The T4 forums have some of the smartest folks on the net.. I'm unsure if they monitor the bus forum.
Welcome to STF.
doc
Site Admin
Post by doc »
Welcome to STF. We're glad you're here and ready to help.
To ensure you receive the best advice possible, we're going to suggest you also connect into the following T4 specific forum.
http://www.shoptalkforums.com/viewforum.php?f=1
We appreciate you joining STF!
Doc
59panelvan
the fan i,m taliking about is just pushing air over the cooler not into the engine bay
MNAirHead
Post by MNAirHead »
To get you accurate infomration, it would be helpful to see pix
Please post to T4
sorry I did not answer earlier.
Bear in mind, that with the original type1/2 configuration engine of your split....cooling air was pulled into the back of the upright fan shroud....and that cooling air came in from the louvers in the body up high on each side of the bus.
In the type 4 configuration that cooling fan inlet is at the very rear of the fanshroud. On the bus and vanagon....the sheet metal segregated the fan intake from outside air....most specifically the muffler....and again...pulled air from those louvers at each side of the bus. So...it pulled cooling air only from inside of the engine compartment and aside from the louvers ....the cooling intake is sealed away from the outside air.
The type 4 vehicles (411/412)...also had ducted cool air to the fan intake.
So...there is the question. Have you installed sheet metal tin around your engine to make sure that the engine cooling fan only pulls air from inside of the engine bay...where it is supplied by the louvers on each side?
If not...you will overheat. Ray
