Chargeing system on type 3 bus motor
I have a type 3 bus motor I'm putting in a bug. I can't find a voltage reg. for the alt. can some one tell me what Im to do?
- Tom Notch
You will need to clarify your question. A bus motor, when it was based on the T1 36hp thru the last 1600 cc engine always was an "upright" type of cooling. The t3 motor was based on the 1500-1600 T1 motor but with the "pancake" type cooling system.
However when VW started putting the T4 based motor in, 1700-2000 ccs, they were a "pancake" cooling system similar to the T3 pancake version, but that's as close as they are- just Similar.
So taking a wild guess- If you have an upright 1600 with an external regulated alternator, it *may* be a Ghia style alt. so the Ghia regulator may be what you want.
Tom
Tom's Old VW Home
DVKK
DSD, dark side disciples
Tom's Old VW Home
DVKK
Im sorry I have a 1700cc bus motor
And yes I should have said it was a pancake motor, it is a 77 motor from a bus. Im puttin it in cause I'm going to pull a trailer with a sandrail with a 1641cc bug motor in it. I had one once before in a sandrail and pulled a trailer with a sandrail on it before. It does a real good job, with a 67 swing axle rear end. he one I had before a single weber Carb, this one Im going to have a twin carb set up out of a bus.Tom Notch wrote:You will need to clarify your question. A bus motor, when it was based on the T1 36hp thru the last 1600 cc engine always was an "upright" type of cooling. The t3 motor was based on the 1500-1600 T1 motor but with the "pancake" type cooling system.
I did foune a voltage reg, for it at Auto Zone. I have had a lot of the bug shops say they don't make them any more, But auto zone have to order it but they can get one in 3 or 4 days.
So I thank you for getting back with me on this anyway.
Kenny Ball
Wister, Ok
- Tom Notch
Who, sorry to ressurect a long dead thread... But just FYI---
Autozone has the T4 regulators cheap, ~$27.
OReillys has the same part for ~$45 with a lifetime warranty.
Which one is a better deal depends on how good you are about long-term reciept storage.
