Rear hatch jammed on my '69 westfalia
My rear hatch won't open. Any idea how I can open it without damaging anything? I haven't done much investigating yet. Thanks.
- MedicTed
Is the latch unlocked? Is the latch seized? I had the same problem on my '70, and had to use a pair of water pump pliers to open the hatch. Remove the rear mattress (over the engine). You should be able to pull the interior latch release (horizontal bar in the opening of the latch). If necessary, slide the water pump pliers into the opening between the body and the door and use them to help the latch open.
