It is W0081745 staped on the engine
Can some one tell me if it is a 1700cc engine
and if it would be any good in a fiberglass dune buggy
Anyone know what a W engine is
- david58
Welcome to the STF.
Porsche 914
Code: Year: Engine:
W 1970-1971 1700 (8.2:1 compression, D-Jetronic)
http://www.type2.com/bartnik/enginecodes.htm
Hope this helps.
Porsche 914
Code: Year: Engine:
Hope this helps.
- david58
Re: 1700cc
No but google does.chevboy61 wrote:Now do you know how much hp this engine has and what red line is
http://www.p914.com/p914_numbers_engine.htm
It would be awesome in a FG dune buggy, and welcome to the forums!
The 1700 T4s are about as bulletproof as it gets.
If you plan on keeping it "stock", the DJet FI CAN be made to work quite well, or the excellent intake manifolds can be used to retrofit later>current FI systems like CIS, Megasquirt etc.
With the head gaskets removed for improved reliablility and a CR bump... and well tuned with a good exhaust system etc, it would likely make 90+HP, and pretty much smoke the tires at will on a lightweight buggy.
It is highly recommended that you DO remove the head gaskets, and replace the stock springs, retainers and keepers as these are all VERY iffy when 30 years old.
Replacing the ex valves is also considered a form of "insurance". The valve keepers CANNOT touch each other (must not go all the way around) or the valve will eventually beat itself out.
(The keepers/retainers work like a Morse taper, providing a clamping action to keep things together)
