76 Westy Brake Caliper Thickness
MrGolf
Post by MrGolf »
Can someone tell me what the calipers are new and the minimum thickness before replacement.....Thanks.
WestyPop
Re: 76 Westy Brake Caliper Thickness
Post by WestyPop »
MrGolf wrote:Can someone tell me what the calipers are new and the minimum thickness before replacement.....Thanks.
I'm willing to check the Bentley & even go out & measure my '79, but, I'm not understanding what you want... measurement on the calipers(total thickness: inside to outside?), the pads, or the rotors (new & worn to min.?), or what?
MrGolf
Rotors
Post by MrGolf »
I am sorry. I mean the min and max measurements for the rotors.
wildthings
Post by wildthings »
The wear limit is 11.5mm, or 0.452". Rotor typically have a lip on their edge which will make checking them with low tech tools difficult, but with the lip ground off the rotors are shot if you can slip a 7/16 wrench over the them.
WestyPop
Post by WestyPop »
Original rotor thickness is supposedly 12.9mm, although some of the Chinese-produced rotors may vary from that, especially if clean-up cuts are necessary to make the new cheap rotors even usable.
