http://www.howeracing.com/c-25-suspension.aspx
And click on precision ball joints to get to here:
http://www.howeracing.com/c-510-howe-pr ... oints.aspx
Then take a look around. This company makes racing ball joints for Nascar and others. They also have rebuildable and replaceable ball joints...very high end heavy duty stuff. I can probably modify our existing mount to take a Chrysler screw in style joint.....so i was thinking.
Then I saw this.....click on ball joint housings near the bottom of the page
http://www.howeracing.com/p-7583-precis ... sings.aspx
And look at that three bolt precison ball joint housing...
Since it comes iwthout the internal stud and bushing until you tell them which one you want...I'm betting we could get it with whatvere stud we need...or maybe get one close enough to what our arm size is to make it worth buying a tapered reamer.....Ray
