Brake lights stopped working on my 1980 Vanagon. When I took a look at the switch on the master cylinder I can jump the wires and the lights work so it has to be the switch.
My question is....Do I need to bleed the brakes when that switch is changed? I have never replaced it before so I'm not sure what the procedure is other than simply unscreweing it and screwing a new one on and plugging it in. So I thought I would ask if the brakes need to be bleed after installation.
Thanks.
