Split window windshield sprayers...how do they?
- Jadewombat
Come out? I don't want to break them. The pop out the top or bottom? Set screw?
Re: Split window windshield sprayers...how do they?
Never actually dealt with a split window sprayer, but if its like other cars, you will have to get behind it and squeeze in the tangs to get it to come out.
- fusername
yeah I have a feeling they are all the same, two tabs on the back side you can compress w/ some needle nose vice grips, then simply push out. look in a parts catalog to see how they are. only trick is there are two tabs you can compress, and two tabs that are acutally solid and dont do anything, compress the right ones for best results.
- sideshow
Threaded nuts are the normal for factory or dealer installed.
- Jadewombat
OK, thanks Guys, I'll take a look. The bus is in the paint shop and I didn't want to break anything getting them out.sideshow wrote:Threaded nuts are the normal for factory or dealer installed.
