1. Two 17mm rear sway bars from 4-speed 411/412
2. 944 front sway bar drop links
3. 17mm Prothane bushings
The 944 drop links are made of 10mm treaded rod (vs 8mm stock). They are rated for a 30mm hollow sway bar and a much heavier car. The bushings are 17mm - same as 411/412 rear sway bars. They fit perfect, have bushings that are available, and are strong enough to handle the increased load transfer. A broken drop link would be a very bad way to exit a corner... upside down.
The Prothane bushing make coupling the bars very easy and avoid binding.
The stock bushings were replaced with the same Prothane bushings, but a 1" rasp was needed to modify the width and height to fit the stock mounting brackets.
The results are excellent! Body roll is significantly reduced and the tires are working noticably (audible) harder. It corners so well that I've considered replacing the cushy stock front seats with one's having firmer side bolsters, but in memory of Travis I won't.
Buckle up and hang-on,
Bill
