17 volts!!!?!?
Every car has an electrical system. Here's the place to learn all about it.
Mathias
17 volts!!!?!?
Post by Mathias »
Got a new alternator with internal regulator. but when I started the motor it's putting out 17 volts at 900 rpm (engine-speed)... I have connected the main wire to the battery and the warninglight ot the flat connector.
Have I connected it wrong or is this a sign of that the internal regulator is broken?
Speedy Jim
Re: 17 volts!!!?!?
Post by Speedy Jim »
You have it wired correctly.
Does the dash light come on when key is first turned and then goes out after engine starts (normal)?
If it does, I would say the regulator is faulty. Call the vendor? Maybe they would send you a replacement regulator module.
Speedy Jim
http://www.nls.net/mp/volks/
